- 30 Aug 2022
- Earth
Yes they are.
Cheers. Ten year warranty certainly helps!
Yes they are.
It's been so long since I've bought a PSU, I've no idea which brands and/or OEMs are reliable but I'm assuming Corsair are still up there?
How did you find the install?Bought this today to swap with a EVGA G2 850 that’s 8 years old as I just upgrade to 7900 XTX and 5950X to give me more headroom.
I will see how practical this is once installed in a Phanteks P600s
If he ordered from ocuk he won’t have it yet. Yesterday they told me there dispatching ordered from Wednesday the 15thHow did you find the install?
Thanks! Forgot they are moving to another site.If he ordered from ocuk he won’t have it yet. Yesterday they told me there dispatching ordered from Wednesday the 15th
Just saw this, it was an easy install and practical but you need a case with a lot of space at the side of your case.How did you find the install?
Edit:Just saw this, it was an easy install and practical but you need a case with a lot of space at the side of your case.
I don't see it as innovative. it's just another corsairs marketing trick.They Shifted the Modular Panel!
The new Corsair RMx Shift series brings innovation a side-positioned DC connector panel. According to the brand’s claims, this provides a tremendous boost to cable management since users have an easier access to the modular panel. Moreover, all Shift models are ATX v3.0 and PCIe 5.0 ready.
That doesn't sound like a biased statement. Honest.I don't see it as innovative. it's just another corsairs marketing trick.
Corsair power supplies are the best. It works well honestly.That doesn't sound like a biased statement. Honest.
