Hi,
Im looking at the corsair TX650 to replace the usual lame PSU in a Dell PC. the old PSU measures 150mm x 140mm x 86mm.
However, depending on where i look, i get different specs for the TX650. OC here says its 150x140, some sites say 150x150 (ie 5.9"x5.9") and corsair themselves have 150x150. so will the real measurements stand up please!
if you actually have one of these, i'd be grateful if you could measure for me.
however, i need a PSU roughly of this output and none others i can find with 140mm, so i might have to find a way to fit it (or another model) anyhow.
the case has little indents at 140mm, i could punch these out if i had to. this is the measurement away from the back of the box, so there's space to extend here a little.
thanks for any help or suggestions.
