FunkyT said:I'm guessing most of the OcUK members leave their PCs on 24/7?
Quite the opposite, if I recall correctly.TaKeN said:Does your pc wear out faster if you leave it on 24/7 ?
TaKeN said:I don't leave mine on for more than 24hours.
The only exception is when im downloading torrents![]()
Al Vallario said:Quite the opposite, if I recall correctly.
Starting up and shutting down are the two most stressful times for computer hardware, I believe.
MikeHunt79 said:I'm using an epia m6000 computer, with 1 120gb hard drive, and the whole rig uses less than 50W.Around half the power of a normal lightbulb.
plus the spikes from the switch can damage sensitive electrical componentsFireskull said:Yep thats what ive been let to believe aswell, this is what ive been told anyway that because some of the metal stuff is so small, constant hot and cold dosent do it very good? but then again constant isnt very good on our elec bill
