daztrouk said:yep, the elements expanding and contracting if i remember correctly
Yea,
Nope, blue fans & case lights annoy me @ night!FunkyT said:I'm guessing most of the OcUK members leave their PCs on 24/7?
MikeHunt79 said:I'm using an epia m6000 computer, with 1 120gb hard drive, and the whole rig uses less than 50W.Around half the power of a normal lightbulb.
afraser2k said:Same here.![]()
dwarf said:How much power does the moniter and peripherals draw as well? I know they arn't left on all the time but they must add to the cost!
ste_bla said:Guys what OS do you use on them and what sort of things can you do properly? ie DVD Playback DIVX Playback TV Recording etc
Also which version do you use 1ghz or the 1.3ghz?
Cheers!
Al Vallario said:Quite the opposite, if I recall correctly.
Starting up and shutting down are the two most stressful times for computer hardware, I believe.
Ah cool one other question do the drivers that come with it work for 98se + 2k?afraser2k said:Epia M6000 is the VIA 600 MHz version (fanless). I'm running Debian GNU/Linux on it in command line mode only as a 24/7 server. Various duties include web server (Apache), local DNS (bind), file server (Samba) and streaming media (GNUmp3d) so that I can listen to my collection at work. It was built more as a Linux play-thing rather than a serious server/project.
The M6000 didn't cope at all with DivX and wasn't great using PowerDVD when I tried it under Windows XP. If you're looking at multimedia I'd recommend the 1.3 GHz version.
Using a low spec CPU doesn't mean it will use less power, if anything the opposite will be true. Because it is low spec it will be running at high load more often. You would be better off getting a more modern low voltage CPU if you want low power consumption.jellybeard999 said:I have a file server / download box on 24/7 ... my HTPC and game machine get knocked off every night.
I built the file server as a low power machine :
Celeron 1ghz, mobo with everything onboard + PCI Gigabit LAN card + 6 HDDs... cant be drawing that much power, and am using a very efficient 500w Zippy PSU - so it'll be drawing what ? 80w ish i reckon ?
AFAIK my P4 2.6C system only uses around 100W at idle, if that. It's only under load that power consumption shoots up. The Epias might be frugal but they're as slow as hell.MikeHunt79 said:I'm using an epia m6000 computer, with 1 120gb hard drive, and the whole rig uses less than 50W.Around half the power of a normal lightbulb.
dirtydog said:AFAIK my P4 2.6C system only uses around 100W at idle, if that. It's only under load that power consumption shoots up. The Epias might be frugal but they're as slow as hell.
