- 25 May 2011
Want to add some fans around my AV receiver as its hot, notice you can pull the fan cable apart and attach to a USB cable, but remember there where some Volt limits that it wouldnt work with
I am looking a the Yate Loon 220mm Fan Blue LED
Would it work ok ?
Technical data:
Dimensions: 220x220x30mm
Supply voltage: 12V
Speed: 600 r / min
Flow at 12V: about 147 m³ / h, 31 (dBA)
With 3-pin Molex connector 60cm cable
Would it work ok ?
Technical data:
Supply voltage: 12V
Speed: 600 r / min
