Hi all,
hoping somebody can assist me - I'm looking to complete my first ever custom loop. I'm currently running my 3600 cooled by an Arctic Liquid Freezer 2 AIO. I want to also have my 2080 Super under water, but not a fan of how the Kraken G12 kit looks, aesthetically. So I'm planning on a custom loop just for my GPU. Maybe will throw the CPU in the loop one day, but the AIO keeps it plenty cool at the moment.
So I'm hoping somebody can help me with a parts list, I've read a bit into what I need, and I've decided I'll go for a soft tubing loop with it being my first go. I'll get the GPU waterblock used, so really I just need help choosing the rest, which I believe is going to be:
Radiator (I'd like a 240mm), not overly thick as my case has some clearance issues with the motherboard.
RGB Radiator fans
Pump
Resevoir
Soft Tubing
"Compression?" fittings? Not sure what fittings I need.
A nice light blue fluid.
I assume I'm going to have to sacrifice my rear exhaust fan to fit the pump using a fan bracket, but if anyone has any better ideas I'm happy to listen
Thanks for any help! I'll be sure to post any progress when I know what I need. Also any "I wish I knew this" advice for my first attempt would be great
RGB Radiator fans
Pump
Resevoir
Soft Tubing
