Could someone with a full height GPU and a SG05 case take a measurement for me please?
Caporegime
13 May 2003
Warwickshire
Hi, please could you tell me the distance between the top of your GPU and the bottom of the case?
I'm considering buying a passively cooled Sapphire HD6670, however the heatsink extends over the top of the PCB:
It's 13cm tall according to the Sapphire website. Will it fit a SG05?
Many thanks.
I managed to fit a PowerColor HD5850 in mine which according to the PowerColor site is 13.5 centimetres tall so you shouldn't have a problem, I didn't need to mod anything. The bundled PSU with the SG05 is really efficient as well, it managed to run my E8400, 4GB RAM and the 5850 with no problems at all.
Hi Robbie. I haven't actually opened my case to check. but here's a quick idea just from the outside.
From the bottom of the card's Pci bracket (almost exactly the bottom of the case) to the top of the case is about 17cm. I have the PSU support bracket in place so perhaps you should knock a cm off that, giving you 16cm, more or less.
From the top of the Pci bracket to the top of the case there is about 5cm (again, not taking into account the PSU bracket).
HTH, and if you want me to take the cover off, and measure it properly, just give me a shout.
Going off topic a bit.
Just checking no mod comment included not altering the case front for auxiliary power leads to fit? And your 5850 card was 265mm long (reference cooler model not on Power Color site)?
I've just measured the length of the card and it's about 250mm. That was without taking it out of the case to make 100% sure though because it's too fiddly getting it all out just to put it back in. :p
I had to take the fan out of the front of the SG05, then I put the card in and connected the power cables, then I put the front fan back into the SG05, didn't need to cut any holes or anything like that. :)
I had a similar sapphire heatsink on a 5550 and an sg05 and the heatsink knocked against the top of the case and stopped it fitting in :(
The main problem, as I see it, is that there should not be any part of the GPU heatsink extending over the back of the GPU, because the space for the CPU cooler in the SG05 is very limited, especially with 1155 MITX boards.
Also, the airflow in the SG05 is not that good, and one should aim, if possible, for a GPU with an external exhaust, or at least one that does not exhaust too much hot air towards the front of the case, in a direction opposite to the airflow from the 120mm intake fan.
I have MSI GTX 550Ti cyclone 2 OC. It fits, with a bit headroom left, but I have to say it was difficult to maneuver because the tip of the heatsink cover is a bit tall.
Yep it's the 300W version. :)
Cool. I've actually now got the SG06 300W running a Zotac G41 with a E2140 at 1.76GHz (:(). Incidentally, that's as far as it will go with any voltage on this board!! Considering this chip was upstairs running on a P35C-DS3R at 3.2GHz (3GHz every day usage), that's not a great overclock! So if anyone wanders upon this thread wondering whether or not the Zotac G41ITX-A-E overclocks...it doesn't :p.
What exactly was the card rodo? SAPPHIRE Ultimate HD5550 1GB DDR2? As that looks the same as the one in my OP...
Regarding space at the back of the GPU, that's not a problem as the Sapphire in my OP is only 7" long, whereas this case takes 9" cards.
Regarding your point about cooling, potentially...except my CPU is running very cool (passive under a Gemini II) as it is not being clocked very far, and I won't be overclocking the GPU very much as I'm only using this for HD media and fairly basic gaming.
I run my SG05 2with specs below -
i5 2400, 8gb DDR3, Asus Direct CU GTX 560, Seagate hybrid drive and 450w PSU, all fits pretty snug.
Thanks for that. I know the GTX560 supports bitstreaming of HD audio over HDMI, but I'm not sure how plug-and-play and flexible it is compared to ATI 5xxx and 6xxx cards that have supported this for ages. That aside, it seems like a really good card for a gaming HTPC.
I have to say I'd discounted nvidia GPUs for HTPC duties, but it seems like I need to do some more reading about them.
