Cheers Stulid, is the 8350 worth the extra £30 over the 8320 ?
No not overclocked since the AMD barton days and the cooler is stock, thanks for the help now to explain to the missus why we need to spend more money![]()
Cheers for the advice on the cooler, the case is Zalman Z11 Plus Midi Tower Gaming Case.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-043-ZA&groupid=2362&catid=2277
I think for none-overclocking the Themis is more than adequate - no point in spending a large amount of money for a non-overclocking heatsink!
I don't, I think the Alpenfohn is the better cooler and fan.
However as the OP won't be overclocking, I think the Themis or similar is more than adequate as it's a great quite heatsink and the brocken is about £7 more which isn't really needed, but obviously it's up the OP at the end of the day!
