Quick bit of background
A little while ago I needed to undergo a quick fix upgrade to my old system.
Right now I have
I'm now looking to upgrade the GPU and (or) CPU and would like to know the minimum I should be considering to be able to multi box in WoW. Only looking to run two instances, one on each monitor.
I definitely want to replace the HD7970 as it is very loud and wont run WoW at Ultra settings.
Budget is tight, so would a GPU upgrade be enough and should the G4560 be capable paired with a better GPU of running two instances of WoW.
Ta in advance
Right now I have
- G4560 3.50GHz (Kaby Lake)
- Gigabyte Aorus GA-Z270X-Gaming K5
- Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-19200C14
- HD7970 GPU (bought from MM)
Ta in advance
