- 13 Sep 2012
So currently running a 5950x with an EK Velocity block, love the block it's performance is great but unfortunately aesthetically the RGB LEDs really let it down.
RGB on it when set to white has quite a blue hue to it compared to the rest of the systems LEDs (I've even had a replacement set of LEDs from EK with the same problem) and I've even thought of manually resoldering new LEDs but finding replacements not as easy to source as these blocks use 3535 SMD LEDs unlike the common 5050 and maybe thats a reason for the colour issues but anyway couldn't find anything that I know would work
So unfortunately it looks like just for aesthetics I'm gonna change the block
So my questions to you all are, what block would you recommend and why? And have you personally owned the block and can confirm the LEDs are primarily white when set to white and not have the EK blue hue?
