So I took my CPU out to clean the thermal compound off and managed to damage it. Diagnostic guy says its fried.
This is the CPU
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) - Retail
and this is the motherboard
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
Can anyone recommend a replacement CPU that will fit the motherboard. Hopefully the motherboard is not old enough that I need to replace that as well.
Many thanks for the help as usual.
This is the CPU
