That comment was in regards to the expert.
As always seems to be the case with these "experts" they don't know as much as they like to think they do.
Definately try a new PSU, or disconnect everything bar one fan from the PSU and short the green and balck wires on the 24pin connector to see if the PSU powers on for long enough.
Did you read the whole thread? He narrowed the problem down to either the CPU or the motherboard. I've only tried a new CPU so far so he could still be right.
That's where all the pc experts areI had a expert diagnose it and he narrowed it down to the motherboard or CPU.
I noticed the CPU temps were really high 90c+ so I took the heat sink off and cleaned off the old compound with a tissue and come rubbing alcohol and then re applied some fresh compound. When I plugged the CPU back in and attached the heat sink, the PC booted up for about 3 seconds and then powered down again and kept doing this over and over again.
I took it to a guy down the road that does PC repairs and he said I've probably fried the CPU when I took it out.
Hope the expert has given you a refund now you have ruled out the CPU!
Have you tried what wazza has said? Bios may have screwed, just need resetting?
Hope you didnt pay for the 'expert advice'?
The best thing we can suggest is to reset the cmos (see motherboard manual for details). Then, unplug all peripherals and just have the motherboard running with nothing but the CPU. The aim will be to try and get it to beep. Then start adding in the RAM, GPU, etc.
If it's not beeping at all we need to try something to encourage to do so, at least so we have a starting point.
When you do the CMOS reset, do it with just one RAM stick in the first slot. Then if that doesn't work, replace it with the other RAM stick and see if it will boot properly.
If it is bent socket pins, i wouldn't know how to solve it apart from replacing the board. Bent CPU pins on phenoms and FX CPUs i have fixed by sliding a credit card through to straighten them. Don't know if that works on the Intel sockets, id imagine it would. If the board is broken, you don't have much to lose i suppose.
My money is on a sketchy power connection between motherboard and PSU or messed up BIOs.
he didnt charge me a penny. It was taken from me on a no fix no fee basis. He was kind enough though to tell me he had narrowed down it wasn't the hard drive, ram or PSU and suspected when I had taken the CPU out its likely that was it or when I blasted the board with a can of air that might also have damaged something.
Did you use an anti static strap when removing, cleaning and reinserting?
Bent socket pins are really hard to sort out, but it can be done. I use a wooden tooth pick and a magnifying glass, though you're still going to go boss eyed any way
The wood tends to grip them quite well.
