Hey y'all, I've been pondering novel ways of keeping my GPUs quiet and balancing the temps on another thread but this issue has come up a couple times. People are suggesting my CPU is bottlenecking my GPUs. My specs below but short version is I have an OCed AMD 6300 @4.2GHz and two GTX780 GHz editions.
Full system specs:
So the thing is, one chap suggested that my CPU was probably bottlenecking my GPUs so I did a bit of research. The symptom of CPU bottlenecking is having high CPU use and low GPU utilisation. My CPU doesn't seem to have high usage but the chap said it was probably because the games didn't use all the cores and were maxing out 4 cores so what looked like 66% usage was actually like a 100% bottleneck. So I posted a screenshot from my Roccat Power Grid on my phone showing that while playing Metro 2033 Redux in 4k I was getting 50% usage spread across all 6 cores:
In response to which Threepwood later said this:
So I've just run the Valley benchmark in 4k with some other system monitors and it shows high usage of the GPUs, 98% and 74% in this shot, and quite low utilisation of the CPU spread over 4 cores for the most part.
That screen cap has been halved from my native resolution but you can still just about read it. Ultra settings, no AA and no v-sync almost 60fps.
So my question is, is my CPU bottlenecking me? What other tests should I run? Don't get me wrong, I'm no AMD fanboy, I just figured the OCed 6300 would do the job 2 years ago when I bought it. I worry that behind the scenes, something to do with PCI-e lanes is slowing me down, I'd like to go Intel but I really don't want to upgrade until I can afford something DDR4.
Any advise, suggestions please? I'm happy to run more tests and post results.
Full system specs:
asrock 990fx extreme3
AMD FX-6300 Six-Core Processor OCed to 4.2GHz
8gb dual channel DDR3 1866Mhz
Corsair H55 cooler
128gb Samsung 840 Pro
2x Seagate 1TB Hybrid Internal Solid State Drive in RAID 0
Windows 7 Home Premium 64bit
2x Gigabyte GTX 780 GHz edition GPUs in SLI (same BIOS, rev etc despite differences with decal and heat pipes)
Superflower leadex 750w Gold
Inateck PCI-E to USB 3.0 2-Port PCI Express Card (for the USB 3 front panel as the mobo didn't have a USB 3 header)
Asus PB287Q 28" 4K 60Hz 1MS monitor
Corsair H55 cooler
You are looking at the wrong useage to know if your CPU is a bottle neck.
Your CPU load % does not matter, what matters is your GPU load %.
If, for example your 780's were running at 100% load each then yes, your CPU is not bottlenecking your GPU's.
It would not matter a jot if your CPU load was 10% or 100%.
You have already had a correct answer, sell your board and cpu and put that and your £150 towards a better CPU, one that will not bottle neck your 780's.
You should monitor your GPU load.
