I did.
Although it doesn't contradict anything I've said.
Just because you lack any thinking beyond a one line comment doesn't mean the rest of us should.
In certain situations the AMD can be better, there is no way around that, for gaming and other situations that need the core for core performance, it's Intel.
I mean there's quite a few benchmarks there which show FX8350 > i5 3570k.
Not that I think the FX8350 is the better CPU, however in the heavy workload situations where you can make use of the cores it *can* be.
This heavily threaded software and situations exist now, they're not made up, they're not stipulations, and they're certainly not hypothetical.
Ignorance doesn't make you intelligent DG.
EDIT : To expand for your simple mind.
If one did a review with 10 heavily threaded benchmarks, and 5 lightly threaded benchmarks, it may be that the FX8350 in that review is overall faster.
You can then get another review with 5 heavily threaded benchmarks and 10 lightly threaded benchmarks, in that review it may be that the 3570k is overall faster.
It all purely depends on what software is used within the review. You can't in any circumstance give a blanket statement with a made up figure, because it simply doesn't hold true. One may use heavily threaded applications in a working environment where the 3570k may come up trumps, would you suggest they get the "faster" 3570k in that situation? No, because that'd be stupid.
I won't buy PD CPU's for gaming myself, because I want the best, that is Intel, but I'm not going to bury my head in the sand and chant "Intel, Intel" as you are currently doing.
Pick the CPU to fit your software, end of.
And if you're going to reply with another poorly constructed rhetoric response full of nothing, don't bother.
