I run @ 3.725 24/7 atm as I done need a huge amount of vcore for that and temps are sensible at low fan speeds.. Also tbh day-to-day you probably dont notice any difference over 3.2/3.4, only place you notice it is in benching and e-pen
IMO No reason to spend extra for Q6700 unless you need extra 0.5 on multiplier - hint, you don't![]()
Unless you can get a cheap Q6700, they are binned higher so will overclock higher in theory.
Definitely the Q6600. The Q6700 is obsolete to anyone who knows how to overclock.![]()
Off topic, but does anyone know if there are any QX6700s that are G0s? I might be able to get one for about £150 but I'd want a G0 instead of a B3 as I've heard they get pretty hot and are less overclockable?
No!Q6600 everytime
