- 16 Dec 2010
i need a cpu cooler less than £30 for a quad core, am3 socket. The cpu cooler must be less than 165mm in height
i was about to recommend the gelid, but i see someone already has. you should be able to get 3.8 out of the phenom with that cooler.
speaking of which, i really ought to overclock my PC since ive had this cooler for ages and done bugger all with it
I think it only supports one fan, to add a second you probably need to improvise.
by improvise do you mean use sellotaping, bluetacking or even gluing the fan
Yup.
duh, i never thought of elastic bands. never knew somthing so simple could be effective.Elastic bands are good.
Or glue gun
