Hey guys
I am looking for a new CPU cooler.
I have been looking round quite a lot and it looks like Noctua is the brand to go for because i am hoping to make my pc allot quieter.
Also i would like to be able to overclock my CPU
Currently have an AMD stock cooler on an:
AMD Phenom II 965 C3 Rev (currently stock clocked)
i was looking at this cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-NC&groupid=701&catid=57&subcat=
but fear that my case will be to small specs are:
270x470x430mm (WxDxH)
Will this cooler fit or is there a better cooler i could fit some quiet Noctua fans to.
Also i am planning to get a new case in the near future currently looking at the Cooler master CM690 II Advanced and fitting some Noctua fans to make it quiet would this be a good choice.
Cheers in Advance
Regards Ryan
Also to add my currently my idle temps are 50 degrees C and load can be up to 60 i hear that max for these is 62
Cheers in Advance
Regards Ryan
