Is your Vengeance ram have the tall heatsinks on?
Some options below:
http://www.overclockers.co.uk/showproduct.php?prodid=hs-000-pt
http://www.overclockers.co.uk/showproduct.php?prodid=hs-015-nc&groupid=701&catid=2330&subcat=2346
The RAM you have is high profile
What's your budget?And are there any cheaper???
What's your budget?
Agreed, currently on a k2 mount doom that was bought as a replacement for the supermega. Seen an 8c temp drop on the i7 920 @4.2ghz in the pic above, (77c-69c on highest core). Like you say, the mega is great for tall ram, used it with ocz reapers. The megahelims though needed high speed fans to get the best from it, in my case akasa vipers. Quite loud at full speed, whereas the stock k2 fans are a lot quieter. Of course the larger surface area of the k2 makes a difference too.Megahelms is a great cooler with tall RAM. Mount Doom with Low profile modules.
