Cpu cooler for mATX
23 Jul 2012
Hello,
I am currently researching parts for a new pc, and require advice on a cpu cooler. For the time being I intend to use stock settings on a i5 3570k.
While i'm sure this should be ok I don't know how good the stock cooler will be in a mATX setting (fractal arc mini case). I may overclock slightly a couple years down the line.
If you think the stock cooler should be fine (I would like temps below 60c) then that would save me some trouble. Otherwise I have a £ 30 budget for a cpu cooler but unsure as to which will fit without restricting air flow too much.
Thanks in advance for any advice.
ps. mobo will probably be asus p877-M or MSI z77MA.
