cpu cooler looks bent
That video EsaT posted is a good watch on how cooler heat pipe transfers the heat..
I suppose only thing you need to worry about with air coolers is the fan bearing wearing out but I suppose that takes year year of use any way...
Indeed, it shows how well heatpipes heatpipes transfer. In our coolers it's heat being removed, so here's a link to heat transfer instead of cold transfer. Skip in to about 1:15 to see it.
https://www.youtube.com/watch?v=2vk5B6Gga10
Heatpipes are vacuum sealed with low pressure so the liquid in them (water) boils at much lower temp than normal .. low enough that heat coming off of CPU chip boils/vaporized the water expanding it many times and pushing the previously vaporized gas toward ends of heatpipe where is condenses to much smaller area (liquid) in the wick on inside of heatpipe. This liquid then moves (wicks) it's way back to cooler base when it again vaporizes starting the cycle over again.
Its such a big surprise that this method is so basic but effective and surprisingly cost efficient compared to aio coolers, and even with a mild basic overclock air coolers can still do a very good job and still hold there own.
And there was me thinking these heat pipes on these coolers was a cast iron rod that slowly transfer heat from the cpu 2 the fins and the fans attach cools not just the fins but the heat pipes also.
Here's trio of vids showing whole CPU cooler making:
https://www.youtube.com/watch?v=p71V6zLybig
https://www.youtube.com/watch?v=BBB2rChWxmE
https://www.youtube.com/watch?v=JKG1au3y-NU
I've had few very cheap and short 30 khour life specced Scythe SlipStream fans fail in some 4-5 years, but they started making "warning" sounds before stopping.
More advanced sleeve bearing fans last lot longer.
And fan failure wouldn't kill all cooling power and CPU would still operate well at idle/light load.
While in waterpipe coolers with their many additional degradation/wear mechanisms all eventually lead to catastrophic cooling loss of CPU overheating at idle.
And in case of pump failure it can happen instantly and without warning:
You just power PC on and before Windows has loaded fully CPU is throttling heavily and possibly even doing thermal shutdown.
Or simply shuts down if pump fails during say game play or other major CPU load.
Iron is way poorer heat conductor than copper with only 1/4th of thermal conductivity. (and stainless steel just poor at 1/5th of that)
Even silicon used as base of semiconductors and CPUs/GPUs themselves is 50+% better heat conductor than iron.
Actually from solid materials diamond would be the best heat conductor.:p
And while waterpipe cooling is 18th century or something like that product, modern heatpipes are actually "space age" product.
They were developed for thermal management in satellites, which have major issues with surface exposed to sun literally baking, while shadow side is cooling toward absolute zero.
Along with absolute maintenance free and reliable operation requirement.
Nothing beats operation by the laws of physics in reliability...
Big dual tower heatsinks have way more surface area for dissipating heat into air than average especially slim radiators.
Even single tower heatsinks have lots of surface area.
For example sub £50 price Scythe Mugen 5 has 85mm deep fin stack.
Compare that to max 25mm thickness of typical radiator.
Well after watching the above video which is a eye opener i will never look at air coolers the way i did before.
copper tubes, copper powder , few droplets of distilled water, air vacuumed out and ends sealed simple but so effective with no moving parts but just a fan or fans.
And to think you can even hold 1 of these copper tubes in your hand and it will melt a ice cube.
All i can say is that i am sold on air coolers as aio really do seem like a lot of hassle for what you actually need ie pumps, rubber tubes, liquid cooling and it seems like a disaster waiting to happen and basically its all marketing hype and a money spinner..
Recieved a new warranty cooler today from arctic coolers and i must say there customer service is really good, i knew they was going to send a replacement but with whats going on in the world everything is delayed.
I installed the cooler and im blown away by how low my temps are and they are so much better now ,In cindebench 20 cpu do not go above 69c and before it was reaching 84c and its scores
well over 200 pts more than my previous scores?
call of duty is 55c in game but loading new games it reaches 65c, again these temps are so much lower compared to the black arctic cooler.
The pc idles as low as 43c now but it always fluctuation between 43c to 52c in idle?? maybe the paste hasnt bedded in yet im not sure???...
but i am well impressed with these temps but now im thinking maybe is it a good idea to go in bios and ramp my cpu cooler fan up a tad i dont know??
