- 9 Jul 2010
The best way to remove thermal paste is exactly as J.Col states, personally I would not advise using nail polish remover as it is likely to leave some residue.
To remove any remaining residue I use a small drop of 99% Isopropyl Alcohol on a paper towel, then use another drop on a paper towel for a final wipe, it evaporates in seconds.
You can use 70% Isopropyl but for the price difference get the 99%. Rubbing alcohol also works but make sure it does not contain "Lanolin"
Please note: its not for drinking!
