I have just recently purchased pc spec below. I have connected it all up, at first when powering on PC I noticed CPU fan did not start stright away took 4 seconds. Next it stayed on the screen saying detecting IDE devices for a long time, so hit DEL into BIOS. Got BIOS screen went through checking settings only changed few minor things like system time and boot order. Also enabled CPU warning settings for temp. Powered off computer and switched back on, now the CPU fan has stopped running and getting a loud ongoing Beep, I switched the system stright off as guessing the CPU is over heating if the cpu fan is not running. The fan is connected correctly. have tried a few attempts but cpu fan still failing to run. Should I buy a new CPU cooler? Anyone recommend one?
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
1 - OCZ 1GB (2 x 512MB) PC2-6400 Dual Channel Special Ops XTC Series DDR2 (OCZ2SOE8001GK) (MY-070-OC)
1 - Seagate Barracuda 7200.9 160GB ST3160811AS SATA-II 8MB Cache - OEM (HD-093-SE)
1 - BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
