CPU cooler under £60?
Yes. Using a Akasa PWM splitter
http://www.akasa.co.uk/update.php?t...es&type_sub=Fan Cable Adapters&model=AK-CB002
Is available for 2, 3, 4 & 5 fan splits
The master fan is one of your CPU cooler fans plugged into splitter CPU fan socket. Splitter plugs into motherboard CPU fan PWM socket and molex from PSU to power fans. All fans run on the same PWM signal... The PWM signal that is controlling the rpm of the master fan. As long as other fans are similar rpm range they will run at about the same rpm. ;)
I'm running 7 fans in my case this way.
I use ET6 to setup my PWM speed on my old EX58 UD3R. Idle/browsing is 700rpm and prime will see 1100rpm @ 60c. I could ramp fans to full 1300rpm but see no need when everything in case is so cool.
Cheers, they sound brilliant.
Any idea how many I'll need? Got room for 4, and 2 140mm fans. Obviously won't need 6, but unsure how many I'll need.
Just grabbed 2 of those above. How many do you think I'll need for the whole thing? Would 2 120mm fans be enough? Will I need a 140mm, if so, any suggestions?
Cheers.
2 of which above?
In my R2 there are 2x 120mm front intake and 1x 140mm bottom intake with 1x 120mm top back exhaust and it's cool.
Remove your extra PCI slot covers so GPU heat can slide out the back
