cpu cooler
Man of Honour
31 Dec 2005
England
can anyone recommend a good cpu cooler for athlon 939 3500 cpu please?
zalman looks quite nice any others?
yeah, i've been wondering this for ages too, i dont really care what the best value for money is, i personaly want to know what the very best air cooler is, somone mentioned the syth ninja, but OcUK dont stock them, it looked pretty cool, a pasive cooler but able to mount a 120mm fan to it *coughdeltacough*
okimanoob said:
CPU Temp 23c at idle + 32c atfull load.
I have a Panaflo 120mm fan running @ 21Dcb
:D
i aint saying your a liar but are you sure your motherboard is reporting the correct temps? as 23c idle for the cpu is pretty impressive seeing as room temp is usually 20-23c.
Yeah thats near impossible, even the best water cooling kits can only cool to around 9-10c over ambient when under load... unless you live in siberia or something you would need a delta at least
:o
Asus Probe is showing 46c - after pc being on for 6 hours
It seems my T/Take Hardcano 12 is only reporting 23c (which is what I based the figs on) - so might have to re-position probe to get more accurate read outs.
:D
okimanoob said:
:o
:D
Thought so :p
Doesnt seem quite so good now my CPU is @ 31c
Ive just fitted a Freezer pro and im very impressed, its matched the watercooling that its replaced!
29 idle and 44 load (speedfan reportings)
Hi,
my cpu was idling today @ 22°C so yeah my vote goes to the Thermalright series coolers (Thermalright eat Arctic Cooling anyday!).
I heard the XP-120 *may* perform 1°C better than the SI-120, but the latter is a lot more compatible with motherboards which is why I bought it.
Fits on my ASUS mobo 100% perfect, can access DIMMS1,2,3,4 as normal etc.
It's a no-brainer, the Thermalright coolers are where you wanna be at if your into air-cooling, your never gonna get this type of result with a £14.00 Heatsink, also with the Thermalright you can choose your exact fan match to suit your tastes (Hoover, silent, UV etc).
are you sure that's right?
My reference cooler only shows 43 at load with both my cores running folding for 24hours ? :confused:
how noisey are all of these coolers ? ( just out of interest)
i mean really ?
i hate noise, and im a total sucker for buying things cos of the way they look lol.
any intel temps ?
I like my Zalman 9500. Haven't tried a XP120 but have used Asetek Micro Extreme, Freezer 64, Zalman 7000 and a thermaltake K8...it's better than any of those easily. On full it's pretty loud but bearable.
Temps are 32 idle, 47 load, 250x12, 1.52v.
Is that at stock though?
Bear in mind mines got a 50% overclock and is at 1.6v
I have got an Akasa AK913 only about 20quid and it comes with a fan controller as you said you didnt like noise! My opteron 144 @ 2.6, 1.55V (only had it for a few days) is at 29 idle and about 40 under load with the fan at a bearable 3000RPM
