CPU Cooling questions
19 Feb 2011
Hi all,
Currently im running an Antec Kuhler 920 with 2 Enermax PWM fans, its lovely and quiet at full tilt on my i5 2500k @4.4ghz, temps hit 60c or so playing BF4 for extended periods, im happy with this, but i feel if i want to push the cpu further that going back to air might be better as i dont want the hassle of a custom loop etc.
With that said i like the look of the Prolimatech Black Genesis as it will clear my Corsair Vengeance Ram heat spreaders, plus i bought 2 Prolimatech fans ages ago (Blue Vortex) and never got round to using them.
These fans are not PWM though so i think adding a fan controller will help really tailor the system, im looking at the Bitfenix Recon, so i should be able to plug the fans into this. I have a CM Stormtrooper case which has built in fan control i was planning on leaving this controlling the case fans and using the Bitfenix Recon to control the CPU fans only.
My question is will i need some kind of extension cables for the fans to reach the fan controller? ideally i would like to cable manage the fans cables as well as possible.
Whats prompted this is i want an R9 290 Card, and i know they have mad heat issues so i would like to cool my system as well as possible on air before adding this card and the extra heat its going to generate.
Thoughts?
The recon comes with extension cables.
The 290 pushes the majority of it's heat out of the back of the case, so I wouldn't worry about what it does to internal temps too much. By all means provide it with cool air though :)
