- 2 Sep 2013
That's fine, we know the GPU (as I have it too) can just throttle down properly anyway if needed (for now whilst you test).A detail that I forgot to add it, the GPU will be vertically mounted.
The key thing you want to know from turning the AIO fans (preferred test) from Exhausts to Intakes or the Rear fan, is if there's enough pressure to push the air in/out as needed (and take the warm air out along with it) through the leaky sides of the case. Because of that case design, the leaky gaps means if the fans are setup rather neutral (like your 3/4 setup), the heat (if it outputs faster than you can remove) might be just soaking everything inside and temps are just going to be higher. But if we give it enough pressure (positive in this test example hopefully through a 6/1 fan setup) to move everything out via those leaky gaps (and the Rear Exhaust), hopefully that'll show that it was merely an airflow and pressure issue and then you can decide then on what remedial action to take. (Different fans - if the fans aren't doing it, or if the AIO fan direction change was enough - whether to make it permanent or not).
Right now, it could be any number of factors, so you may as well eliminate the quickest one first before you spend (even more) money to solve it.
