CPU Equivalent
31 Jan 2007
Hello,
Can anyone specify what the equivalent AMD AM2 processor is to the Intel Core 2 Duo E6400? It needs to be compatible to the Asus Crosshair Motherboard.
Regards,
Neil
Can I just ask: If i purchase this processor:
AMD Athlon 64 X2 Dual Core 4600+ 2.40GHz (Socket AM2)
Will it run at only 2.40? or double with the dual core to 4.80?
Sorry about this. I'm not really up in processors.
Thanks
Neil
Is that the same with the Intel Core 2? If so then is the speed written on the box the doubled up speed? - Then why are there not any higher speed dual cores?
Thanks
Neil
Hi,
Due to improved efficency of the current range of processor they run slower but do more work per clock cycle than there previous counterparts, higher the mhz more power is needed and higher heat output.
Core 2 duo are dual core so each core runs at the stated speed.
Hope the above explanation is ok.
Rob
:eek: You dont add the totals of the 2 cores together. What you will have is 2 separate processor cores in one package each running @ the stated speed.
So, Is having a dual core 2.40Ghz processor better than having a single core 3.40Ghz? Will it run faster and more efficiently.
Thanks
Neil
dual cores work on 2 threads - so do twice as much work
Operating systems are 1 thread and 2 thread compatable generally
2 thread means 2 processes working at the same time
1 thread is 1 process at a time.
Both will be 2.4 or what ever processing speedyou get.
