Hi all, I have just completed my first build and I am having an issue. Have used search but couldn't find anything about this.
On the first boot of the system I got the error message "CPU fan error press f1 to continue" upon inspection I saw that my cpu fan was spinning really slowely, I could see the logo. It span at the normal speed on initial boot, but by the time it was in the early post, or bios it was slow. When I went into the bios it said it was spinning about 450 rpm. The minimum speed was set to 600 rpm and I couldn't change it.
After some googleing I ended up disabling "cpu q control" and now the machine boots ok, when I'm in the bios it says the fan speed is about 1400 odd.
My question is really what have I done when I disabled q control, why have I had to do it, will it damage the machine having it disabled and can I fix it so that I can enable it and have the cpu fan working?
The cpu cooler was attatched properly and plugged in to the right sockets etc, two of us double checked and triple checked.
Mobo: ASUS P8Z68-V
CPU: Intel core i5 2500k
Cooler: Be Quiet Dark Rock Advanced
Thanks in advance!
Mobo: ASUS P8Z68-V
Thanks in advance!
