So, earlier i turned the Desktop on and after a little sway the fan rotated fine. However, for the first time that fan error message never displayed, it went right through to "starting windows". Great!
I turned the Desktop off and tried it again another 2 times, same thing happened, going right through and running normally. 4th time however it did the usual swaying and never fully rotated to start itself off. 5th time it did the same thing, same goes for the 6th. By the 7th time i gave up and manually tilted the Desktop to get it working so i could come on here and post about it.
When it rotates fine, the message doesn't show up (now got it in the right connection so as expected), but when it doesn't rotate enough to get itself running the message displays. Could this be a power issue? I don't want to throw the towel in and call "faulty product" without trying out some more tests, but i don't know what it is that i could try out. As for the RPM/"running too slow to start" mentioned earlier, how do i go about setting a minimum fan speed for this product so on start-up it will spin a bit faster?
