- 12 Feb 2006
- Surrey
Im running my self built system almost a week old now, specs in sig, and at first it was fine except i got a problem with the speakers, when the computer started it bleeped, twice quickly, then 4 times slowly, which according to my mobo manual meant that there was hardware problems, so i installed a driver from the mobo CD and it went away.
Then the next couple of days the bleeping came back and after it finished bleeping a messege came up and it said CPU Fan Error. this is where i am stuck as i have no idea how to fix this. I have unplugged the CPU fan plug thingy and put it back but nothing changed. Is there a way in checking what is wrong with the fan? e.g. by checking things on the bios, and also what temperature is the CPU meant to be when not in use and when in use, in use it sometimes get around 43/44*C is this right?
thanks in advance
thanks in advance
I never know which way on the power LED connector goes so just put it on. If its wrong, just rotate 180 and try again
