CPU fan header
23 Sep 2008
On my P5Q-E the fan attached to the CPU heatsink is a 3 pin, not 4 pin, so I have it plugged into a 3 pin header on the mobo. When I start up the system is tells me there isn't a CPU fan, so I'll have to press f1 at each startup. Should the 3 pin fan work in the 4 pin header, or is there a way of bypassing the reminder at startup? Thanks.
you should be able to connect the 3pin connector to the 4 pin header on your mobo as the locating lug on the 4 pin header is offset for this purpose to be backwards compatible with 3 pin fans :)
Tried that after looking in the manual at the pin descriptions, but the fan didn't move.
Found the BIOS setting I needed, had to change CPU Fan Speed from [N/A] to [Ignored]. (In case anyone wanted to know)
It might have been the CPU was very cold, which is why the CPU fan didn't move, Asus QFan probably decided it didn't need to spin the fan up as it wasn't hot enough. Did you wait till you got in to windows first? I would put it back on the 4pin CPU header.
It should still 'see' the fan though. Have you set the fan control to voltage instead of PWM?
I don't know how to do that, so I highly doubt it. It could be that it decided the CPU wasn't hot enough, I guess, and I'm still waiting on Vista to come through the post. I don't think I'll worry about putting it on the CPU header, as the motherboard uses QFan on the chassis headers too, and I've got a second CPU fan running as well--cooling should be fine.
If you are going to leave it on the chassis headers does q-fan on these headers work at different temps to the cpu header?
Just make sure that you have set the cpu/pc to shut down at a safe temp i.e. no more than 90 oC for example
I have the P5E, 3 pin Zalman CPU cooler. Depends how you plug it in. Looking at board from above, plug needs to use pins 1-3 inc, not 2-4 inc. Using 2-4 indeed doesn`t spin fan.
