Hi, just finished putting it all together and my arctic freezer 7 pro does not spin on startup. I'm using a gigabyte ds3 mobo and, yes, the fan is plugged into the cpu_fan socket. It doesn't move at all but i do get the single beep on before i turn in off.
Has anyone else had this problem with this cooler? Should i try replacing it with the stock fan?
cheers for the help guys!
are you outside or something???
