Cpu fanspeed?!?
14 Dec 2005
Hi there,
Ive had few problems that past couple of days. Firstly i started getting red lines up and down my screen and cant play games without getting a BSOD.
So ive been thinking my gfx is broke but i just installed a motherboard program from there site (MSI mobo, Dualcorecenter) and as soon as i installed and opened its alarming me that my cpu fan speed is low which is 969RPM and temps are 42deg.
Ive also went into bios to double check this and its same in there, so can this be my problem with my screen and not being able to play any games or you still think my gfx card is dead.
Pc Setup:
MSI Powerup Edition
Duo E6700
2GB G.Skill PC2-5400
Vista Home Premium 32bit
FSP Epsilon 700W PSU
BFG 8800GTX 768MB
X-FI F4tality
My post about gfx card = http://forums.overclockers.co.uk/showthread.php?t=17732585
Thanks for any help
mine runs at same speed idle and 1200 over a certain temp so seems ok, im assuming you have a 12cm fan
and i do think your gfx card is kaputski its showing the usual signs
