CPU Faulty? i9-9900k - System restart on loading into x-plane other games.
23 Jan 2019
Good morning all, i'm not really new to the scene but i am having a few problems it seems, to get to the short of it,
my CPU with AI on at 4900mhz is fine, everything is perfect i try bumping this to 5000mhz and the game crashes half way loading, I've tried over and over again bumping it up and i'm 100% sure its when it hits 5000mhz as the CPU could be defective? it's not a cooling issue in the slightest, everything is put together properly and I've had it double checked
(The stats below the cpu is running at 65c which is totally wrong, my core temp and AI suite is 30c must be a error within the gpu-z programme.
To note i am using the Cooler Master MasterLiquid ML360R Addressable RGB CPU Cooler - 360mnm (all hooked up and running properly
"So just to recap when its running like it is now at 4.9mhz it opens xplane all is fine perfect - when i reboot and it ticks to 5mhz i open xplane and then it instantly restarts - heat is fine so it cant be that"
My POWER SUPPLY is a 650w (cooler master)
Below are my full specs
CPU Name
Intel® Core™ i9-9900K CPU @ 3.60GHz
Threading
1 CPU - 8 Core - 16 Threads
Frequency
4897.6 MHz (49 * 99.95 MHz) - Uncore: 4297.9 MHz
Multiplier
Current: 49 / Min: 8 / Max: 50
Architecture
Coffee Lake / Stepping: P0 / Technology: 14 nm
CPUID / Ext.
6.E.C / 6.9E
IA Extensions
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Caches
L1D : 32 KB / L2 : 256 KB / L3 : 16384 KB
Caches Assoc.
L1D : 8-way / L2 : 4-way / L3 : 16-way
Microcode
Rev. 0xA0
TDP / Vcore
95 Watts / 0.608 Volts
Temperature
68 °C / 154 °F (WRONG)
Type
Retail (Stock Frequency : 3600 MHz)
Cores Frequencies
#00: 4897.60 MHz  #01: 4897.60 MHz  #02: 4897.60 MHz  #03: 4897.60 MHz 
#04: 4897.60 MHz  #05: 4897.60 MHz  #06: 4897.60 MHz  #07: 4897.60 MHz 
Model
Asus ROG MAXIMUS XI HERO
Socket
Socket 1151 LGA
North Bridge
Intel Coffee Lake rev 0A
South Bridge
Intel Z390 rev 10
BIOS
American Megatrends Inc. 0602 (10/19/2018)
GPU Type
NVIDIA GeForce GTX 1080 Ti (GP102) @ 1556 MHz
GPU Brand
EVGA Corp.
GPU Specs
GP102-350 / Process: 16nm / Transistors: 12000M / Die Size: 471 mm² / TDP: 250W
GPU Units
Shader Units: 3584 / Texture Units (TMU): 224 / Render Units (ROP): 88
GPU VRAM
11264 MB GDDR5X 352 bit @ 5575 MHz (Micron)
GPU APIs
DirectX 12.0 (12_1) / OpenGL 4.5 / OpenCL 1.2 / Vulkan 1.0
if looking for a 5G+ OC on all cores it's best to overclock from within the UEFI
5GHz can need anywhere in the region of 1.25 to 1.4v under load depending on the CPU sample, and even then, not CPU can achieve this. Moreover, judging by how quickly the system crashes when bumping the multiplier it's possible 49 is conditional, too.
A CPU not reaching a 5Ghz Overclock doesn't mean it's defective.
Only if the CPU doesn't work at stock settings, then you may consider it defective.
The moment you overclock your CPU/change voltage/increase multiplier, you run the risk of having an unstable overclock.
Even though most 9900K owners can, it doesn't mean that 5Ghz overclock is guaranteed.
yep its cpu lottery. Mine runs upto 1.5v for 5ghz on the rare occasion but normally sits between 1.3 and 1.4. But i don't have mine running at 5ghz constantly.
I have a stable I9 99OO at 5GHZ with the voltage on auto.:)
This is one my system the limit without playing with the voltage settings
I also fly Xplane 11 with no problems.
My motherboard is a Asus Strix Z390F
I've seen on here people achieve 5Ghz at 1.26v, I'm not so lucky. 5Ghz all core takes at least 1.28/1.38v for me.
Defiantly better to overclock from the BIOS though. Don't assume someones settings will work for you because that is defiantly not the case 9 times out of 10.
