Hi there! I have noticed that the last week Desktop PC's CPU fan makes an awfully loud noise. Even when idle. So i checked speedfan and Gigabyte's Utility ET6 and it shows that CPU fan runs at 5500 rpm!!! When Idle! It goes to 6000 rpm under load.Cpu temps when idle are around 50 C and goes to 70 under load. My system is AMD X4 Phenom 965BE, Gigabyte mobo MA770 UD3, an 275GTX and 4gb RAM.
It IS hot here in Greece but not that hot!
Is CPU in danger?
Is s'thing wrong with some controller regulating fanspeed?
How can i fix it (and the noise
)? SHOULD i fix it?
Many thanks in advance!!
Is CPU in danger?
)? SHOULD i fix it?Many thanks in advance!!
