posted quite a while back with regards my p4 3.4 prescott and unbelievable idle temps
current temp atm is..... 66c @ idle
thats with side off case and case out in the open
I had this issue before but temps then were hitting 80c @ idle but replaced the cooler with a thermaltake copper one, temps dropped to mid 30's idle = ok
now they are making gaming impossible as I am certain its causing the cpu to throttle due to high load/temp
monitor temp using both bios and everest
how the hell can i drop these temps, would cleaning cpu/cooler, apply as5 and a case fan at rear make any diff?
would a dual fan psu help? current one came with pc and whilst its not the most powerful system runs ok with a x800xt 1gb ddr, 250gb sata, dvdr/w and dvd rom inside
got a bit of cash coming but dont want to upgrade if i can get away with it but atm I cant really do a lot with this pile of silicon crap
