CPU Heavy Gaming Rig (My attempt at build - looking for advice/changes)
8 Jul 2019
Hi all,
I'm about to engage in my 4 yearly new PC purchase. This time around I'm looking for something CPU heavy with a high single-core clock speed (OC). GPU needs to be passable to play upcoming AAA (Cyberpunk etc.), but doesn't need to be running on Ultra and 90% of the time it won't be breaking a sweat in the other games I play.
Games I play:
Dwarf Fortress
Kerbal Space Program with RO/RP1
X3 with Litcube and Mayhem
etc etc.
So CPU heavy games which are POORLY OPTIMISED for multi-threading.
Here is my attempt at a build:
CPU - I5 9600K (I3 9350 KF has also been suggested, but I'm hesitant to trade off SUCH a lot of multi-core processing - and also I'm unsure that you can actually get that I3 to clock higher than the I5 even though the base clock starts higher).
Board - No idea, but something like a MSI - Z390-A PRO ATX LGA1151?
Memory - G.SKILL Trident Z DDR4 3600 C17 2x8GB (Not sure if there's a better choice at $160 price range)
GPU - Nvidia 2060 6GB (Only needs to be good enough to 60fps AAA games for 3-4 years on med-high settings, nothing more).
SSD - SAMSUNG 970 Pro 512GB - speed is everything.
Cooling - Something effective which fits... loudness not an issue.
Monitor - 1080p TN 24' standard. Later down the line I'll likely buy a 1440p IPS 27-31'.
Case - Any ATX mid. Doesn't need to have millions of bays or designer labels. 1. Easy fit. 2. Easy Access. That's it.
PSU - 500-600w from respected brand. Don't care about efficiency but at least Bronze rated.
Let me know thoughts,
Cheers,
R
That was the case until a few days back when the new gen launched, not that you can go wrong with Intels offerings but it would make sense to look at both options fully.
Have a look at the Ryzen 3000 series and see what you think, in my view it would make no sense to buy an i5 at the moment.
Yes, you're right. I'm loathed to go AMD as I had bad experiences, but that was over a decade ago... Will keep an eye on benchmarks as they come out.
A price drop in Intel chips could also be nice.
