CPU hot after system build
31 Dec 2010
Hi all,
Ive just finished building my new system, booted up into bios and was surprised by the temperature of the cpu.
Its a new ASUS motherboard, new I7 950 chip.
I used my old Arctic Cooler Freezer 7 Pro heatsink. Started by cleaning the base with tissue, then thermal cleaner using cotton buds. Applied a slim line of thermal silver to the cpu, and put on the heatsink. A little swivel and screwed it in.
But even with the tower cover off, I was getting these temps:
MB: 30c
CPU: 45c
My first thought is I should take off the heatsink, clean it and the cpu. and start again. Maybe I didnt apply the compound properly.
My question is, what temperature should I be expecting?
45c just feels abit too hot for my liking.
Plus, can a heatsink base get damaged over time? I noticed whilst cleaning the heatsink base (with a tissue to remove the previous compound) that it was entirely flat. there are several tiny craters. Could this be a problem?
An alternative is to try the stock cpu heatsink, but I was expecting much better performance from the arctic cooler.
Luca
Even though the AC7 is a good cooler, I fill it may struggle with a i7 - If you see my point :)
Also I think the BIOS puts the cpu under a little load.
Havent tried on max load yet. I dont even have any drives plugged in yet. Just wanted to boot into the bios and check memory, cpu, temps.
So are saying I'd get better temps from the stock heatsink, than from the AC7?
Maybe I should put the stock on instead?
The AC7 is better than the stock heatsink, but not as great as the Thermalright Ultra or Titan, In fact any heatsink is better than the stock version :p
Once your fully operational run Prime 95 or equivalent and check full load.
Well I left it sitting in the bios screen for 20 minutes, with the tower case off. And its slowly crept up to 50c now.
Like you say, I'll run it for another day, see if its settles in. If not, I guess I'll try again.
I don't think SpeedStep applies in BIOS, so it runs at full speed all the time. Hence why it crept up to 50c. Really suggest you install Windows and see the temps from there :).
I don't think that temperature sounds right. While I was setting up my i5 build with a Freezer Pro 7, CPU temp was at around 29C at idle in bios with the side of the case off. 50C CPU temp at idle sounds like the heat sink isn't fitted properly.
Fair enough. I'll agree that the load temperature is what matters. Surprised an i7 would idle 20C higher than an i5 with the same cooler though.
Im still convinced I didnt do the thermal compound very well. I tried doing a small pea sized blob but the compound is quite sticky so it ended up as a trail across the cpu. I then struggled to line up the heatsink with the screws, so I mustve smudged it quite abit, whilst moving it around.
Ok, so I cleaned up the heatsink and chip, reapplied some grease. And got bios temps of 45-50c.
Installed windows 7, and HWMonitor. From that I saw temps around 50-55c for the cores.
Installed prime95 and ran a blend test. And within about 2 minutes, the core temperatures reached 81c. At which point I paniced and shut everything down.
I know that i7's run hot, Ive read that everywhere. But 81c after 2 minutes of stressing just feels scarey.
Maybe I should replace my heatsink, I saw some good comments for a coolmaster?
And for now, maybe I should remove the AC7 and put the stock cooler on. Because the AC7 just feels terrible from what Ive seen.
i wouldn't panic at 80C
its very difficult to damage a cpu thermally.
and most cpus can run without problem upto 100C
which if set right, the pc will auto shutdown when it reachs those kind of temps.
however, 80C does seem abit hot if not Overclocking.
how much paste did u put on when u did it ?
did u remove the paste from the heatsink before applying any more ?
as most heatsinks tend to come with paste already applied
too much paste can trap air and prevent heat from transfering effectivly
