- 4 Mar 2010
Ok, so my old pc keeps shutting down and on reboot gives me the message the cause was a CPU overheat, sometimes it then stays on, sometimes it will then die again.
Basically after taking the case apart i have found the fan and heatsync are clogged with dust i have loosend it with a paintbrush but as i have important things to do on there now, is it safe to use a hairdryer on cold to blow the dust off?
Cheers.
Cheers.
