CPU Problem?
30 Aug 2005
Right, been having so many problems with my machine and after taking it in for repairs have been told it's def. the RAM that's causing the issues. So I ran with one stick for a while and it worked fine, so I ran Prime95 to see what would happen and basically after two cycles the machine would just reset/BSoD (think it gave an IRQL less than or equal error), I have new RAM on the way so I'll try again with that. I also get the same error when trying to run Bioshock aswell.
But is there any chance that crashing while running Prime95 shows that my CPU might be the problem? I don't think it's overheating as it's showing as running at 28c.
Running a Q6600 with the Thermalright Ultra 120 extreme.
