Caporegime
- 9 Nov 2009
- Planet Earth
Exactly how long will a 5820k longevity last? Im in the same boat considering an upgrade for long term from, a 2700k and it looks like Im gona hold on, an ivybrige would help for PCI gen 3 but short of MM which I dont have access to they are hard to find especially brand new as a short term upgrade on Z77 to utilise a second 980ti. However long term I would like to see a processor that would handle 3 screens at 4k each gaming in a few years when GPU"s can realistically manage that. Would a 5820K be capable then? If not then if i was buying now ild go for 6700k just for the best there is now cause I would need to replace the 5820k anyway at some point.
The Core i7 6700K is a rubbish value CPU at £300+ and makes a Core i5 6600K at £200 or a Core i5 4690K at £170 look awesome value.
But look at how much the Core i5 6600K is now on OcUK?? That price is not far off IB and Haswell Core i7 CPUs.
Even in gaming benchmarks the Core i7 5775C can do well against the Core i7 6700K due to its L4 cache and is usually cheaper,and you do not need fast DDR4 RAM to make the most of the platform,and will work fine in socket 1150 motherboards.
You even have a decent IGP for backup too.
Any of the newer quad cores without HT are perfectly fine for gaming and if you need extra multi-threaded performance the Core i7 6700K will get destroyed by a Core i7 5820K - plus the platform will be supported with 14NM CPUs too. If the HT on the Core i7 6700K is "important for gaming" then imagine how the extra cores on the Core i7 5820K would help??
The Core i7 6700K is just nowhere in its product segmentation. The ST performance on the Core i5 6600K is similar,and the extra money can go towards a better graphics card,or a better cooler to get a better overclock and the Core i7 5820K might lose some ST performance but destroys it for multi-threaded performance.
If I were you,I would stick with your Core i7 2700K especially if its overclocked TBF.
The whole Skylake pricing structure is ridiculous.
It just comes across as companies like Intel wanting to milk desktop PC enthusiasts,so they can spend billions on subsiding things like Atom tablets. It doesn't help AMD is not really competing either.
