How would I know this, I unplugged the old AIO pump and then plugged the new one in where the old one was.Have to ask the stupid question after looking at your fan rpm, have you plugged the pump into a fan header?
The air out the exhaust is cold air.
Yeah brought new from pc specialist in nov-21, 3 year labour warranty and then various parts warranty depending on the parts/manufacturer warranty. But this cooler is band new only arrived today from Corsair. So has 5 years on it.did you buy your computer new? and where from?
should it not have had a 3 year warranty? (not sure where you buy it from - ocuk has a 3 year warranty)
I can send it back for like £60 shipping which is why I went for the cooler first as it was nearly the same price.@Prof_Cookie50 can you not send it back to them for them to diagnose and rectify the problem?
that's why you paid a pretty penny for the warranty (even if you have to pay for the extra component to fix the fault)
which part of the uk are you in? if you're close to brum i can have a look lol
what have you done exactly? was something not wired quite right?After the rewire we are down to 50/60°c idle
I took all the new wiring out, and then re followed the instructions to plug it in again, I think I may have mixed up where one of the pin connectors goes.what have you done exactly? was something not wired quite right?
you connected the Y-connector incorrectly didn't yaI think I may have mixed up where one of the pin connectors goes.
Maybeyou connected the Y-connector incorrectly didn't ya![]()
It's a Corsair H60x elite 120mmlooking at the hwmonitor screenshot, from the values for cpu and fan rpm, i would has a guess to it being a pump issue in regards to it being too slow to move enough water to cool the cpu guessing pump speed is slow and maybe the issue. what aio do you have?
icue software installed at allIt's a Corsair H60x elite 120mm
I have it now that it's calming down, I felt there was no need when idle it was at 100°cicue software installed at all
How would I be able to test this to see? And I could manually set the BIOS to put all fans on max to see if the CPU still clocks 100°c
Should I see about a replacement cooler to double check it didn't get delivered dead on arrival? Or is there a way to tell?
