malc30 said:As we are guessing it can't be the ram as it shows it @ 2gGb.
What about the way it reads it as single and you have to add it up to get your actual clock ?
At least this guessing is keeping it on front page until one of the clever ones tells us
BTW Have you been in the bios and looked at the settings iin there ?
How long have you had the system ? who built it if new etc
PilotTait said:fancy explaining how to do those things you just said![]()
- Load factory defaults = ...
- CPU multiplier unlocked
many thanks!
PilotTait said:anything else i need to change to get it to run as its meant to?
8MB L2 Cache, need to do anything about that or will that be ok?
Main Test Results
3DMark Score 11423 3DMarks
SM 2.0 Score 4576 Marks
SM 3.0 Score 4764 Marks
CPU Score 4072 Marks
Detailed Test Results
Graphics Tests
1 - Return to Proxycon 38.048 FPS
2 - Firefly Forest 38.215 FPS
CPU Tests
CPU1 - Red Valley 1.366 FPS
CPU2 - Red Valley 1.942 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 43.636 FPS
2 - Deep Freeze (SM 3.0) 51.649 FPS
