cpu speed jumping about
16 Dec 2010
When I look at CPUz my speed on the CPU jumps back and forth between 1596.4 and 3392.4 mhz
What is causing this? Some setting in my BIOS I assume
Only if you want it :p
It won't affect stability, or performance - just saves you electricity by reducing the volts it uses based on it's activity.
Mhmm means yes.
I'm lazy and accustomed to saying Mhmm xD
It's a BIOS settings, but I'm not familiar with with P67 BIOS, sorry!
Sounds like Turbo Boost gone mad!
Turn speedstep off for overclocking I would assume (can't remember whether mines on or off tbh!)
It's Intel's Speedstep. Underclocks and undervolts the CPU when you're idle. Only returns to full power when you're doing something, this can save you electricity. I would suggest leaving it on :).
But if you want to turn it off then you will need to look for Speedstep within your BIOS.
i think you should make sure c-states and c1e support are enabled as well. i noticed if this was disabled, cpuz would report a constant 1600mhz whilst idle, but other programs like msi control centre and real temps the cpu speed was constantly jumping around even if the computer was idle.
I read somewhere that Intel SpeedStep (and AMD PowerNow! ) can change the CPU frequency thousands of times a second. I have never had performance issues with it on, even when over-clocking. I would recommend leaving it on if you tend to leave your computer on between using it.
To turn it off in Windows XP just *don't* select "minimal power management" as the power scheme. Otherwise disable it in the EFI/BIOS.
