cpu speed
You're not giving much information.
What CPU?
What was the overclock set at?
Did you run something to stress the CPU while CPU-Z is open so it shows your maximum CPU speed?
this is what i bought from over clockers but had some isues from my old gpu after a while so i replaced it and think i might of turned it back to factory settings:confused:
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Overclocked Bundle
What CPU?
you an always check under system in the control panel and that will tell you?
I overclocked tonight and that matches my bios.
i had downloaded from download and got a stupid checker . deleteded that and got it from cpuid direct and sorted it now
cheers
