Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
jh30k, you have been reported for your abusive trust message.
Maybe its just the games you play? I assume you are playing modern fps's. Try playing the game in a window, and see if that helps. For me I've tried it and it knock 20c off my temps.Hi,
I've recently built a new gaming PC using a Gigabyte GA-78LMT-USB3 motherboard, AMD FX-8320 cpu and Zalman CNPS8900 Quiet cooler.
I've been using Speedfan and HWmonitor to check CPU temps and something odd is happening. At idle it sits at a comfortable 30-35 degrees C, which I thought was a decent temp. But when I play a game it jumps to 90c.
I thought increasing the fan speed would help when it gets hot but the cooler only goes to 1500rpm max, which it's already hitting. And it's definitely throttling the speed as the temp rises, I opened the case and made sure of it.
Please help!
