Hey guys
For the last month or more, my PC has been pretty slow and my fps in games has been around 20-30 fps, while it used to be stable at 100 on CSS and I could get stable 333 fps on older Q3 engine games.
My PC spec is:
O/S: Windows 7 Professional 32 bit
MOBO: Gigabyte GA_965P_S3 (Socket 775) PCI-Express DDR2
CPU: Intel Core 2 Duo E6400 "LGA775 Allendale" 2.13GHz (1066FSB)
GFX (normal): Asus ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express)
GFX (at the moment): Nvidia 7900 GTX
RAM: GeIL 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Ultra Low Latency Dual Channel + 1GB DDR2 667MHz Ram (Installed 2 days ago)
PSU: Corsair TX 650W ATX SLi Compliant Power Supply
HDD: 160gb 7200rpm, dunno the brand
CD/DVD: Liteon DVD-8900 16x DVD±RW/RAM (Black)
Basically, everything was fine one day and then the next day when I went on my PC it was bust
I already tried to re-format my PC but it made almost no difference(the pc ran faster, but fps was still very low)
I also tried replacing my GFX card with my old one to check if it was that, and it still didn't help :s
So, today I downloaded some CPU monitors and took some screenshots of the temperature in normal conditions, and the temperature in game.
Here are the results:
Normal Conditions:
Playing CS: Source
This is pretty worrying because when I googled my CPU, the temperature was meant to be between 5 - 61.4 degrees.
http://www.cpu-world.com/CPUs/Core_2/Intel-Core 2 Duo E6400 HH80557PH0462M (BX80557E6400).html
What do you guys recommend?
Buying a new cpu cooler? or a whole new cpu?
If you think I should get a new CPU, which one would you recommend which will fit in with my current spec?
Thanks for any help,
Ross
My PC spec is:
!I already tried to re-format my PC but it made almost no difference(the pc ran faster, but fps was still very low)
Normal Conditions:
Playing CS: Source
Ross
