CPU Temp WAY too low
15 Sep 2012
Devon
Recently bought a NH-D14, so I have been watching my CPU temps a lot to see the difference :P
Haven't done any overclocking at all - yet - as according to Core Temp AND HwMonitor my CPU temp got as low as 11C. Now, I do not know my ambient temperature, but I am indoors, and it is not that cold....
The temperature also seems to be changing loads, not really staying still. Though it only changes by a maximum of 10C.
I looked in the BIOS and the temperature was more like 30-32C which seemed about right.
Spec
HAF X Case
FX 8350
Noctua NHD14
Apparently AMD CPUs do not display the correct temperature when idle however, they become more accurate under load (when they are hotter). Many people suggest this but I do not know how accurate it is. My 8350 is similar to yours, but the idle temps are slightly higher.
Yeah, it does seem to stay a little more steady when I am playing Minecraft, though still about 23-25c. That sound right?
Best to ignore what the actual figure is.
Just keep it under 62c. (But the actual temperature will probably be more)
They simply aren't accurate, at very best you can say it's some sort of offset reading, where 62c is actually 80 etc.
Varies board to board, back when I used to clock AMD I had my socket at like 71C and it was fine.
But then you can get boards that get to 62c and throttle etc.
