I have a G3258 CPU and OC'd it 4.2ghz 1.175V and was fine, Idle was at 46 most of the time and would go up to 60's when using Dolphin Emulator and low 70's with Ultra Street Fighter 4.
So I put it back to stock speed (3.2ghz) with default presets and idle is around 43 and it was doing mid 50's when I was doing a simple application form in Firefox.
I'm guessing something is wrong because stock and OC are pretty much the same. Im using the stock cooler and was thinking of getting the CM Evo 212 but I can only use an 80mm cooler . This is the case http://www.cooltek.de/en/cubes/coolcube/2/coolcube
Some advice please
Some advice please
