Ok I just finished cleaning my case (dam lot of dust). Anyways I have become a little concerned with my cpu temp.
I have never ever seen cpu temp below my motherboard temp. Is this right?
The cpu is averaging 27-28 idle yet the motherboard is averaging 29-30. Bios is also reporting the same thing. How is the sensor done and could I have damaged it? Before i cleaned it was idle at 33-34.
under load hitting 38-40
CPU is amd Phenom II BE 965
